Oil in a 14 bolt
Discussion in 'The Garage' started by pomai, Apr 12, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    How many quarts of rear oil should it take to fill a 14 blt ff, with a stock rear cover? I now how to check it, but I was just wondering how much should it take. I put in 4 quarts and it has not reached the axle bearings yet.
    Thanks Ed
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I put in 4 quarts in mine and it started coming back out and flooding my lap... :confused:
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Put in as much as it will take. Put in the fill plug.
    Then jack up one side of the axle really high for 20 minutes. Switch, and do the same to the other side.
    Now top it up.
  4. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Thats exactly what I did. Right on, know I feel confident. Thanks alot. Ed
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    You don't want to risk a dry bearing. Either you need to use an assembly lube - preferably one that will dissolve into the gear oil (i.e. not white grease). Or do the tippy-tippy action I described above. ;)
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    add til it flows out of fill plug hole
    hell i put 5 quarts in my H072 eaton axle and it still aint up to hole yet
    so.,.
    more to add yet,,,
    good luck
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Alright, looks like after I get back from turkey hunting tomorrow I'm jacking up the axle and adding more gear lube.
  8. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I did what you said, instead I left it like that for about 5 hours each side. I'm up to 5 1/2 quarts already, I'll top it off tommorow morning.
    Thanks again. Ed
  9. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    According to ALLDATA, an '82 K20 14bff holds 5.4 pints of gear oil. With that said, mine took 3 quarts to reach the fill hole AFTER I tipped it both directions.
  10. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Is this really true, that it can take 5+ quarts to fill a 14bff? My CUCV manual says 2.1 liters. Now I don't know how much to buy, and I was thinking of buying Mobil 1, which is $8 vs. $2.50 for Valvoline. :doah:
