OIL in intake
Discussion in '1982-Present GM Diesel' started by Tybee, Sep 21, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Pulled my old manifold off and theres oil in the intake, looks like its coming from th 2 tubes that come in the sides. Does this mean my CDR valve is bad?
  2. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Pulled mine off yesterdya, and noticed teh same thing.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Oil in the intake is normal on the GM diesels.
    Casey
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Alot of oil, like caked, I did my heads about a year and a half and it didnt half this much oil in it. And its only been driven about 13,000 miles since then.
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Mine has oil in it too. You can clean it up, but it will go back to the same thing in a little bit.
  6. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Do you still have EGR? If so the "caked" oil could be a combination of oil and soot from the EGR valve.
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Just got rid of it. Im going through so much oil I was hoping it was the CDR. My oil consumption is in consistant I drive 25 miles one time and burn a quart and go 50 miles another and burn nothing.
  8. Oblin Goblin
    Apr 30, 2000
    205
    Davis, CA
    If you're using oil that fast its probly the CDR valve. Try replaceing it and see what happens. They're about $50 at the dealer last time I got one.
  9. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Why did you replace yours and did it work?
  10. Oblin Goblin
    Apr 30, 2000
    205
    Davis, CA
    I replaced mine because after I installed my turbo I blew the rear main oil seal. I replaced the CDR valve because I thought maybe the old one was messed up and not able to deal with the increace in blow by with the turbo. The rear main seal was replaced with a 2 piece rubber seal that supposed to hold up better than the original asbestos rope seal so I'm not sure if the old CDR valve was actually bad or not (I just replaced it as a precation). There seems to be alot less blow by out of the oil fill pipe with the new CDR valve though so maybe it was bad.
  11. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Isn't there a recommended replacement interval for the CDR? Something like 50,000 miles?
  12. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks for the response.
  13. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    If thats the case im probably 168,000 miles over due! Do you have any tubes or breathers coming out of the valve covers?
