Oil in TBI unit..
Discussion in 'The Garage' started by SS66, Oct 28, 2006.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I went to take a look at my fuel injectors... I found something ugly when I removed that plate that allows you to get to them. There is a rubber hose running from the valve cover to the back of the tbi unit where the injectors are housed. Well there is a bunch of black stuff in there. This isnt carbon.. looks like OIL. I assume this is pretty bad..Its not pooling in there yet.. but there is a decent amount.. any ideas on what to do?
    Also.. how does one diagnose whether or not an injector is bad?
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    Blowby... Rings are tired or worse... Mileage?
    You can usually tell an injector is troubled by the spray pattern...
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    You can see the spray pattern from the injectors pretty well if you use a timing light. It will freeze the image making it easier to see the shape. It should have a nice uniform cone shape to it, and no large droplets of fuel.
    What problem are you having that makes you suspect the injectors?
  4. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Im smelling gas and it seems a bit sluggish. Im gonna replace the Oxygen sensor and fuel filter before I invest in new injectors to see if that helps..
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like a lack of maintenance problem to me . Change or clean your PVC valve and replace the fuel filter.
  6. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    Look at the conections, if there bad replace them, if they look like **** then replace them, if there 16 years old replace them. Use your head and common sense.
  7. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    the vacuum line on the rear of the TBI should go to the MAP, not the valve cover....or am I mistaking which line you are talking about?!?!?!?! Or are you talking about the 1/2" line that goes to the air cleaner spacer ring????
