Oil leak, can I ignore? Throw in your 2 cents. VOTE!
Discussion in 'The Garage' started by pvfjr, May 25, 2004.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Finally put my truck back together and took it for a spin after the conversion to manual. Now my engine is leaking oil! It's coming from between the clutch housing and the inspection cover, so I'm thinking rear main? It only leaks when it's running, and for a while shortly afterwards.
    I'm supposed to be headed home, Eugene area, and then down to the California border for some Memorial Day wheeling. Can I ignore this and just try to keep it full of oil? I really can't just cancel the trip. I also don't have a working oil pressure gauge, so I can't keep an eye on it that way. Don't have time to fix it now.
    So what do you guys think? Can I put it off? Don't give a crap about this engine, but I don't want to get stranded!
    How hard would it be to fix later on?
  2. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    How bad is the leak. How big of a puddle does it leave overnight. Could be leaking from the back of the valve covers. Valve cover gasket would be a cheap, quick, and easy fix.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ok, if your going to take the trip, at least install a working oil pressure gauge. I went to Montana and back with the oil pan leaking from the front at the timing chain cover. I didn't have time to fix it, so I kept an eagle eye on the gauge. I had to put in a quart of oil at every gas stop /forums/images/graemlins/yikes.gif
    I wouldn't do it w/out some way to monitor your oil pressure while driving. Waiting till you hear stuff knocking around will kill it dead real quick. Just my $0.02.
  4. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Doesn't leak overnight, just while running. So, I guess the puddle depends on how long I let it sit there. It drips once every few seconds, but would probably add up, wouldn't it? Don't think its coming from the valve covers, unfortunately.
    I have a add on oil pressure gauge, with the nylon tubing, but it isn't hooked up. I don't know where I should run it to. There is a little plug on the side of the engine right above where the oil pan bolts on, would this work?
  5. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    the hook up on my 350 was behind the distributir.
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    The stock one is there, but that's nowhere near as small as this little add on I have.
  7. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    That little plug is to drain coolant from the block.
    If it is not squirting oil, I say go for it. Check it often and take a case /forums/images/graemlins/smile.gif (of oil) with you.
  8. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    If its only dripping, it would take a while to drain 5.5 quarts out of your truck. I would stop every 100 miles and check, if its good go another 100 and check. I have driven my truck with a dripping rear main on 200 mile trips to and from school, I would just besure to check the level before leaving and atleast once on the way home.
  9. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    If you have a four bolt main 350, there should be another oil port at the front on top I guess you could say between the intake and timing chain cover.
    My fitting at the back of the block is an 1/8 NPT fitting, maybe your factory fitting has and adapter. And my gage came with a 1/4 to 1/8 NPT adapter.
  10. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Thank you all for your input. I guess I'll buy a case and just keep an eye on it, maybe try to find that elusive port!
  11. ban-one
    ban-one Registered Member
    Mar 22, 2004
    15
    Bavaria/Germany
    As You use a manual transmission, don't You fear the oil coming from the rear main will smut Your clutch?
    A running engine won't bring You home without traction ... /forums/images/graemlins/dunno.gif
  12. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Although it will take a little while, an oil leak in that area will get on the clutch friction material and will cause it to slip/go bad. Its just a matter of time. A bigger oil leak = less time.
