Oil leak from valve cover bolt
Discussion in 'The Garage' started by mouse, Aug 21, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Drivers side cover, only leaks oil from the rear, bottom bolt. The leak is slow, but yesterday over a 200-mile trip, enough came out to move from the bolt to the reaer of the cover.
    I changed the gasket last week to try to fix it. Used new bolts (proper length) and cleaned everything meticulously. I used Right stuff to hold the gasket to the cover and nothing between the gasket and head. I put a small dab of Right stuff in each bolt hole.
    I'm using cast aluminum covers and not over-torqueing the bolts.
    Kinda lost on a fix. I have some regular thread sealant I could possibly use.
    Any ideas?
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    when I do mine I silicone it on both sides. not a lot just enough to make it stick and get a good seal. either that or get some of those rubber gaskets.
  3. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    yea thats what my rebuild kit came with those rubber gaskets are sometimes even good after being off the head i love mine never leaked yet
  4. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    These are rubber gaskets...
