Oil Leak on intake
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TED, Dec 11, 2002.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I put sealant on my intake manifold bolts twice now and eventually oil leaks up through the threads and it pools on the manifold. What should I use to seal the threads?
    Jeff
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its not your valve cover gaskets?
  3. TED
    Nov 27, 2002
    81
    San Jose, CA
    I'm positive its not the valve cover gaskets. I put thread sealant on the intake manifold bolts and it worked for awhile, then they start leaking again. My boat has a small block chevy and it has the same problem. The oil pools up right next to the bolts.
    Jeff
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    oil should not b coming through those bolts. it sounds to me like your valve cover gaskets r leaking. there is oil that runs through there, but it all just settles down into the lifter galley and shouldnt b coming through the bolts. can u pose some pics?? o yea, one time my valve covers had small cracks in em where the rockers had rubbed on em and rubbed through. so i just replaced the valve covers when i did the intake swap and voila. no more engine oil leaks
    NITRO
  5. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    the rockers where hitting on your valve covers that caused small cracks. They should only hit if they are on the wrong sides. And then you would be able to hear them knocking. Make sure and check that out. Unless they are an after market, I know some after markets will fit on anyway you put them. Im dumbfounded. The seal is on the out side of your gasket, so I dont think thread sealer would help at all.
  6. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    WOW, I just read my own post and it made almost no sense. I will no rephrase it. The seal is on the inside of the valve cover bolts, so the threads would not be the problem. When and if you reverse the correct sides of the valve covers, they knock because of insufficient clearence for the rocker arms. Maybe time for new valve covers.
  7. TED
    Nov 27, 2002
    81
    San Jose, CA
    If it were my valve covers leaking, oil would be pooled up between the head and the intake manifold, but there is none there. Only on the manifold itself. I know the oil should just fall into the lifter valley but for some reason it's not. I'll ttry to send you some pics on Monday because I won't be home until then.
  8. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    if it was coming outta the valve coers, it would still pool up on the intake. pressure wash the engine then see where it is coming from
    NITRO
  9. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    It sounds to me like if your bolts are leaking you need to reseal your intake not the bolts. How does the truck run? Spray just enough brake cleaner at the intake where the leak apears to be while the truck is running. Be sure not to spray to much because you dont want it to get sucked in through the carb/throttle body. If you hear a change in the rpms then you know you are sucking air into the intake.
  10. Tims72
    Tims72 Registered Member
    May 20, 2001
    39
    Lodi, Ca.
    Hey Ted, I know exactly what you are talking about. I have the same problem with mine. It started after I put on the Edelbrock performer intake. I would like to know the answer to the question also. At first I thought it was my valve covers also, but I replaced the valve cover gaskets and still had the little pools of oil there at the end of the day. So I cleaned all the way around the valve cover to verify that it wasn't coming from there.It stayed clean. So I know it is coming form the intake bolts.
    Tim
  11. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    Another thought came to me If you are running vortec heads with a non vortec intake or vice versa.
  12. TED
    Nov 27, 2002
    81
    San Jose, CA
    Yeah, mine is an Edelbrock Performer also. I know it's the bolts because I cleaned everything just like you did and that was the only place it pooled up. Let me know if you find a fix. thanks
    TED
  13. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    Ted I feel your pain. I too not long ago installed a performer(RPM) and the same thing happened to me. /forums/images/graemlins/angryfire.gif It is coming from the bolts!, I too went through the valve cover thing and everything looked good. The sad thing is that I tapped the holes clean with a tap and put new bolts in with black HT RTV on the threads and it still leaked(it started about 4 days after I finished the swap) I had three bolts that were doing it 2 right in the middle on drivers and 1 in middle of pass. Anyway, I took those bolts out 1 by 1 and cleaned everything as good as I could. I then gooped the bolts extra good and reinstalled them. 2 weeks later I finally remember to check them and I found that all but one sealed for me. This time I will clean a little better and reapply RTV and hopefully this problem is gone. I think if I would of cleaned the threads with brake clean and then been a little heavier with the RTV everything would of probably been OK. This is the first time I ever had this happen on an intake swap /forums/images/graemlins/confused.gif Sorry for the book Hope this helps. /forums/images/graemlins/cool.gif
  14. TED
    Nov 27, 2002
    81
    San Jose, CA
    Sounds familiar, the bolts in front and back are fine but the ones in the middle on driver and passenger side leak. I don't remember what I used last time but I'll try gobs of RTV black and see how long that lasts. Thanks Nikk,
    TED
  15. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Is this the stock intake?
    What kind of bolts are you using and how long are they?
    I'm wondering if my ARP bolts with ARP thread sealer will handle this potential problem or if aftermarket intake bolt holes are not quite aligned correctly?
  16. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I had the same problem with oil pooling on my Perf RPM. I used some ARP thread sealer on the ARP bolts and it cured the problem. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  17. TED
    Nov 27, 2002
    81
    San Jose, CA
    Its an Edelbrock Performer intake. I think the bolts are Summit intake bolts, i don't remember how long they are though.
  18. Nikk
    Dec 16, 2002
    34
    Lacrosse, WI
    No, aluminum aftermarket
    Replacement intake bolts off the shelf of local parts place. I didnt measure but they were the same length as stock.
    I think that if you clean things real well from the start and dont be afraid to use some extra sealer on the threads you'll be fine with what you have. The hole alignment was fine. Since the ARP is a better bolt quality wise, it sure wont hurt to use them. /forums/images/graemlins/cool.gif
  19. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I've got the same thing going on...alum intake....so I take it that the screw hole are in a oil line that is under presser and seeping up the threads. I'll have a go at in this weekend
  20. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    No, the intake bolts holes are open at the end in the heads. The oil that splashes around in the lifter valley "wicks" or works its way up the threads and collects on top of the intake. /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
