oil leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Jun 8, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    aight i was feeling around the engine and theres oil and lower bellhousing case and i felt some oil between the flexplate and the block, where could this be coming from?
    phill
  2. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Most likely from the rear main seal. Could also be input shaft seal on the trans. Just guessing tho.
    502Burban
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Bout The only other thing would be the oil pan gasket.
    If it leaks when the engine is running at idle. It is a good chance it is the rear main seal.
