Oil leak
Discussion in 'The Garage' started by 84mudmachine, Jan 23, 2006.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I have a 94 gmc 1500, and I have motor oil dripping from my starter. It's hard to see where it is coming from, but I think it is the valve cover. Has anyone come across this?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    reach back and feel the back of the valve cover, the intake is also i spot i have seen leak a few time causing a oil drip
  3. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    Do you have the Vortec heads? (center bolt valve covers) I've seen the valve cover gaskets crack over time, and a semi-slow oil leak develop. Next time you change your oil, pour a generous amount in quickly, so that it should pool momentarily inside the valve cover. Then check the outside for leaks. If the gasket's cracked, it will be apparent.
  4. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I have another question, can the oil cooler be removed? This looks like a factory unit that runs to the radiator and back, and the line is leaking near the radiator connection. The oil filter screws into the the unit that looks to be between the filter and the motor.
  5. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    check your dipstick tube and check the rear of the oil pan..
    I have oil comming form my dipstick tube cause its not the right one but never know.
  6. 10pax
    10pax Registered Member
    Apr 7, 2005
    95
    Ft Bragg, NC
    Leak Dye?
    The dealerships use an ultraviolet dye that can only be seen with a black light. I think it's only like 6 bucks or so and you can buy a black light for cheap. Clean the engine really good, put the dye in the oil, run it till it leaks, turn the lights off and the black light on and it will be easier to locate. I haven't tried this yet but I have heard some people used it and it works great. The dye is not supposed to hurt the oil properties either. Like I said I haven't used it yet so I might be talking out my keester but sounds like it makes good sense. The Olds dealership in town recommended it before I paid out the wazzooo for them to do the same thing. They really treat me right.
    James
  7. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Can I take the curent hoses of and put in new ones with some hose clamps? Would this hold up to the pressure? I see many aftermarket oil cooler kits that use just regular hose clamps.
  8. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    The 1st oil leak is probably from your valve covers. Clean the engine with degreaser, let it dry, and then run the truck for a few minutes. Mine drips down the sides and hits the (uncovered) flywheel which then gets sprayed on the headers. Let’s just say the Bat Mobile couldn't lay a better smoke screen.
    I also had oil leaking from the radiator. The best fix is to install an aftermarket oil cooler and by-pass the radiator. I just cut the tubing and used a regular hose clamp from the rubber portions. You should really keep an oil cooler for these size trucks for obvious reasons and also the extra capacity that you get lets you carry more oil.
  9. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I went up to autozone and bought some new valve cover gaskets and line for the oil cooler. I just want to make sure it is ok to remove the factory lines and install the new line with hose clamps. Let me know your opinion.
  10. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Is the oil cooler leaking at the connection? Or just before it ? Can you take a piece of rubber hose and slip it over the steel line(assuming it is steel) and clamp it at the leak? This works on tranny lines.If not,try to leave enough there to possibly double clamp the replacement hose, if it keeps leaking.
  11. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    It's leaking where the hose meets the tub, where they crimp the hose.
  12. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Here';s a dumb question...
    Is this really that big of a deal? I leak a little at the motor tranny and trans case, and just keep putting oil in it. I guess if I ever got bored I could fix it, but until then, I don't really stress about it. Am I missing sometjing?
  13. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I guess when I have to add a quart of oil at 2000 miles, it's a big deal to me. Plus, I don't like having a big oil spot on my driveway.
  14. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    I can see that I guess. My truck leaks like a half quart motor 3/4 quart tranny and 1 quart trans case every 3000. I just buy kitty litter.
  15. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    rubber hose and a single clamp at each end will hold the pressure fine. Thats what i have and Ive had no leaks from there yet. Its held up for the past 4 months
  16. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Cool, thats what I wanted to here. I just didn't know how much pressure is in the lines. I plan on replacing the valve cover gasket, oil lines, and check my oil pressure sensor and distributor gasket as well. I hope this cures the leaks.
  17. 88trailblazer
    Apr 11, 2004
    425
    Miami, Florida
    Damn! I never thought of checking for an oil leak at the distributor. That would explain alot. Thanks for the unintentional info!
  18. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Well, I replaced the valve cover gaskets, and fixed the oil cooler lines. After some more looking, it looks like I will be replacing the intake gasket. The darn thing is leaking in the back.
  19. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    My factory oil cooler adapter had a tiny leak, but it was all gone after replacing a shabby old O-ring.
