oil leak
Discussion in 'The Garage' started by chebbykrawler, Aug 4, 2006.
  1. chebbykrawler
    chebbykrawler Registered Member
    Feb 6, 2005
    10
    nevada
    i have a bad oil leak and i cant find it, its coming down the sides of my bellhousing, i replaced the intake manifold and valve cover gaskets, is it possible the head gaskets that are leaking, i have an '87 block and '82 heads, i put carberated heads on a fuel injected block if that helps. any help will be appreciated.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    If it wasn't leaking before,I would suspect the valve covers.It's a good place to start anyways...
