oil leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Peeetah, Oct 2, 2000.
  1. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    While replacing the rear seal I seemed to have developed another oil leak. The leak is in the front of the oil pan where the oil pan mates with the bottom of the timing cover. I used the rubber seal and plenty of RTV but it leaks from the bottom. Is it possible to clean out the RTV and replace it. Could this work?
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    well your prob is that u used the RTV....with the rubber seals you are not spose to use it on them
    "whoo my new pic is on the photo page...check it out!!"
