Oil Leak
Discussion in 'The Garage' started by 88Silverado, Jan 5, 2004.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I HATE Oil leaks and my 88 has one which seems to be coming from above the oil cooler adaptor. Has anyone else had problems with that adaptor? Now the rear xfer case seal leaks too since I did the drop /forums/images/graemlins/frown.gif
  2. dyeager535
    26,977
    There is an o-ring between the adapter and block, but unless you removed it, it's unlikely that would just start leaking.
    You say drop, I assume lowering the t-case? That probably put a load on the crimped on connectors where the lines meet up with the adapter, and I'm betting that's what's leaking. Local hydraulic shop just built my friend a set for about $70 using parts of his existing setup. (the fittings) We swapped motors, and apparently in the process of moving the lines out of the way, the fittings started to leak.
    The later rubber style ones seem to be much more prone to leakage than the earlier steel braided (likely ovebuilt) ones. Surprise.
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Is it coming from above the adapter? Mine had oil leaking down onto the adapter from a little plug up by the oil temperature sender, and from the back of the intake manifold gasket. Major PITA!
