Oil Leak
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TED, Feb 5, 2004.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I have a mechanical auto meter oil guage and it is leaking from the inside. Oil is getting on my foot as I drive. I tightened up the compression fitting a few weeks ago but it started leaking again in a few days. What can I put on the threads to stop it?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Sounds like the line has a crack inside the fitting from being overtightened. It might need a new ferral fitting.
    Bill
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Other than ditching it for a electronic one I would cut off an inch of the tube and try and reinsert it.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    teflon thread tape? maby?
  5. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    If your using the white nylon plastic line, go to napa and get copper and replace it. That plastic line gets heated by the oil and will lose its seal on the ferrul. /forums/images/graemlins/waytogo.gif
