Oil leaking around oil filter BIG TIME
Discussion in 'The Garage' started by 77crewcab, Apr 24, 2004.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    HELP! I have been tracing an oil leak thinking it was the pan gasket. But after cleaning up all the oil that has blown back while driving I started it up and see that the oil is running down the filter and making a puddle the size of a small plate in about 30 seconds of the engine running. Please help me figure out what is going on. I have had this ruck about a month and have not changed to oil yet *trying to fix some smaller problems) could this be an old oil filter gasket that got stuck and is preventing a proper seal. I tried tightening the filter and it is as tight as I can get it yet still pouring oil.
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ok, this shouldnt be too bad-
    First, check to see where the oil is seeping out of- there is really only 3 possible parts:
    1. The oil filter gasket area.
    2. The oil cooler lines (if any)
    3. The oiler cooler lines mating area sandwiched between the oil filter and engine.
    Ok, First things first, clean the area. Check to see exactly where the problem is. It will not hurt you to take the old oil filter off, check visually and by feel to make sure there is no gasket material left on the mating surface. Also make sure to see if the old one was dammaged in any way. Replace with new (pre lubed, including gasket) filter, and see if it sitll leaks.
    Its cheaper now to spend 10 bucks on oil and filters than to spend 1k later to replaced a siezed engine.
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Well no cooler so that eliminates two options. It is just the filter screwed to the block. Problem is can I drive it the 5 mile round trip to the parts store or not. When I start it the oil pressure is really high and will come down after a bit (drove around block to check). Next question is what kind of oil and how much for a 454.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i would not drive it w/ it leaking that bad. u need to pull the filter off & see if that is what it is like pookster said.
    i guess u want to go get another filter? i still would not drive it.
    oil is a personal preferanse that could become a heated debate. personnally i use castrol 10w30 in my 454. mine holds 8 qts, but i bet yours doesn't
  5. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Make sure the gasket from the old oil filter is not still stuck to the block.
  6. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I was actaully just looking for the weight and amount not brand names (I prefer Valvoline Maxlife) so 10w30 should do it. Will I need about 8 quarts then?
  7. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    How long have you had theis problem? Did it come up after you have had an oil change?
    I would start by dropping your filter and like said before, make sure the gasket is on the filter, then make sure there is not another filter gasket stuck on the block mounting surface.
    As far as oil capacity I am thinking it should be a 5 quart system. But I am not sure. It should say on the emission sticker under the hood. You know the one that has the vacuum diagram and such on it. Should be there on the core support.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Is the filter a Fram? If it is, that may be your problem
  9. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    The emissions label has been painted over long ago so no help there. I have fixed the problem now so no worries. It was actually a Napa filter and with no obvious damage and no extra gaskets. But changed the oil with 10W30 and new filter and no more problems. Wound up using QS high mileage since Wal-Mart never has enough Maxlife and a Fram filter. I know, I've heard all the stories about Fram filters but personally have never had a problem with them. Besides I work at Wal-Mart so I get a discount and thats what we carry. Thanks for the help guys. I wound up using 6qts but it is a little full, it will burn off soon enough though (few other leaks to still work on /forums/images/graemlins/tongue.gif)
    Thanks again for the quick replies,
    Monty
    BTW: VERY nice to be able to change the oil with out having to jack up the vehicle. If only they made an 8 inch lift for my cutlass ciera /forums/images/graemlins/thinking.gif
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Wonder what the problem was then...
    maybe the threads ont he filter were messed up and didnt seat right/or fully in to seat the gasket?
  11. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    might have been the wrong filter, if it did not have enuff room to thread on then it would not have had enuff preshure(SP iknow) to seal
    my 2 cents
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Wal Mart also carries a Super Tech filter which puts the Fram filter to shame in performance and costs half the price.
  13. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I've always wondered about the supertech filters but didn't know. The Fram I got was only about 3.50 or so. Anyways I think it might have been the wrong filter but the funny thing is it seemed to be fine the first couple weeks I had the truck. Anyway seems to have fixed the problem seems like the pressure is kinda low though as low as 15 when warm and 60 when cold.
  14. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    That sounds good to me. /forums/images/graemlins/thumb.gif
  15. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    You being serious or kidding with me on that?
  16. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    15psi is way too low, maybe your gage is jacked /forums/images/graemlins/dunno.gif
    Mine runs at 60 at all times /forums/images/graemlins/deal.gif
