Oil leaking from back of oil pressure guage
Discussion in 'The Garage' started by k51977blazer, Mar 30, 2007.
  1. k51977blazer
    k51977blazer Registered Member
    Feb 11, 2007
    71
    Ashtabula ohio
    first off let me say you guys know your **** awesome thanks so much for previous help,ok i have 1977 blazer 350,my oil pressure sending unit it was a metal line it broke, so i replaced it with one from advance auto and that was a plastic hose.Well now its leaking from that plastic hose right where it goes into the fitting does anyone have any used,originial or aftermarket metal lines and fittings or does anyone know where i can buy them
  2. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    just cut the line back and put a new ferrel on... It probably got cockeyeed when you tightened it...
    .02 at your local auto parts. You'll see it when you undo the nut and take it off, the ferrel will have it's "seating band" at an angle...
    nothing wrong with the plastic, just have to properly install the system and route it correctly..
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    except you almost have to change them out every year or so because they get so brittle they break when you move them around while working on something else...cheap sh!t
  4. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    ah, your nuts... :wink1:
    Probably had a dozen in cars over 25 yrs, and have yet to have one fail... :confused: And some where in use for many moons....
    Actually, the one I run now, I snaked thru some small, fancy, high pressure steelbraided line I found, ya know the stuff with white, hard inner line... small stuff, like brake line... worked out awesome.. slid right thru, little shrink tube at the ends and it worked out good...
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    i dunno,,,maybe i bought mine at AUTOZONE :doah: :haha:
  6. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    :haha: damn corporations! :haha:
    Who knows, I may have gotten lucky, guess there could definitely be quality differences from company to company...
  7. bigdave1050
    bigdave1050 1/2 ton status
    Nov 13, 2006
    119
    Queen Creek Az
    LOL.....Could be the AZ heat too:D
  8. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i would just get the copper line that they sell, i had a plastic line break and completly mess my undercairrage.it sucked.
