Oil Leaking from Bolt on Pan..
Discussion in 'The Garage' started by m1ndless, Mar 30, 2007.
  1. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    I an not sure what is wrong, but I noticed that my oil is dripping from the bold you undo to drain your oil. Its not over tightened, but its is really tight, could it be stripped or something?
  2. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    Remove the bolt and replace the plastic washer underneath it and retighten it. Any auto parts store will have them. Don't forget to replace the oil that drains out.....and you might as well do the filter to.:D
  3. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    Do you reply with anything thats useful? The guys asking a question, if you don't have the answer, don't answer.
    Carefully remove the bolt, get a new bolt and plastic washer as stated, change oil and filter, and drink a beer. :laugh:
  4. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    No question is a stupid question, thats how things are learned. Just because its a simple question doesn't mean it requires worthless replys. :)
  5. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Hmm, I thought it had a washer, I will have to check.
  6. Bow-Tie-Boy
    Feb 14, 2005
    71
    Ft. Hood, Texas
    If the washer gets scored or chewed up it won't seal as well as it should. They are real cheap, just pick up a few of them while you are there and throw them in your tool box. You won't have to worry about it for a long time.
  7. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Alrighty, well I just checked it, and changed my oil while I was down there. The washer had cracked, and was slowly dripping, maybe a small 3 inch spot a day, but it has stopped now, I bought a pack of 6 washers for 1.29 at checker today.
    Thanks!
