Oil level in 14 bolt?
Discussion in 'The Garage' started by RodsRVF, Mar 16, 2006.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I have installed a 14 bolt rear end in my Blazer. I had to cut the pads and reweld them to get the angle right for the 6 in lift.
    The question now is how much oil do I put in it and also what to do about checking the level since the "Fill to" hole is angled up quite a bit?
    Thanks for help.
    Rod
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    id just fill it until it comes out.... that is about it....
  3. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    back it up your driveway and check it. Should be level enough
  4. RodsRVF
    Mar 16, 2005
    51
    CA
    If the axle angle used to be parallel to the ground you would fill until the oil came back out the hole. Now that the hole is angled up, would I not be over filling it if I fill until it comes out of the hole?
  5. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    if you back your truck up a hill or driveway, the pinion should be close enough to being parallel then fill er up. Its not going to matter by that much anyway.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Jack up one side of the axle, to get oil to the hubs, then the the other. Jack the right side up last and fill it with the right side jacked up. Should be around 4 quarts.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I say fill it to the fill hole level. Your pinion has bearings in it, it sits higher now, thus you need more oil to lubricate it...
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I put 5 quarts in mine before it went under the truck. We filled it by pouring it in the diff housing while the cover was off. Since the bearings are lubed by the gear oil traveling down the axle tubes I do not feel you can overfill a 14FF unless it is coming out of the vent.:D
    Ira
  9. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    5 qrt stock if i recall last time i refilled mine in stock position.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    put almost 6 quarts in one at work today.
