oil light reset
Discussion in '1936-Present Suburban' started by homemadesin, Sep 15, 2003.
  1. homemadesin
    homemadesin 1/2 ton status
    Aug 17, 2002
    101
    Castle Rock, CO
    i can't remember how to reset the change oil light in my 02 burb. can someone tell me?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The procedure for an '03 Trailblazer is as follows:
    -Put key in run position.
    -Fully depress the accelerator 3 times within 5 seconds.
    I would imagine it's the same for your 'burb. You could also consult the owner's manual if need be. /forums/images/graemlins/thumb.gif
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
  4. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I agree with Heavy4x4. My 02 GMC Sierra is the same way. So is my buddy's 03 Chevy. That should do the trick for you. If it doesn't, there is always the owners manual.
    Kris
  6. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    Step 1: locate the change oil light on the instrument cluster.
    Step 2: clean surface around light on the dash face with rubbing alcohol.
    Step 3: get a fresh roll of Black electrical tape, and cut off a piece that's a slight bit larger than the light.
    Step 4: apply tape to dash face over light.
    this also works for VCR's that flash `12:00'
    -Rich
  7. homemadesin
    Aug 17, 2002
    101
    Castle Rock, CO
    Thanks, I'll give it a shot. I read the manual, but didn't see anything about it. One of the shop techs at the dealer told me once, but I forgot. The wife drives it, so it wouldn't bother me if it stayed on. I would like to take my pistol grip shotgun and blow out the upshift light on my Jeep though.....
  8. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    either that or you if it is like the new rendezvous and such, you will hafta go through the programs with the selecyt button until u find it and once u find it u press and hold the reset button until it clears. but odds are just hit the gas 3 times to the floor /forums/images/graemlins/thumb.gif
    NITRO
