Oil Line Leak
Discussion in '1982-Present GM Diesel' started by jp0863, Jul 7, 2006.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    a few months ago i replaced one of the oil cooler lines. it recently started dripping a little when the engine was running. i tightened the fitting a little tighter and now it leaks alot more... any idea's.? i pulled the line off and the o-ring seal looks to be ok so i dont know where to start looking for why it was leaking.
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't know why that would be, but i had a similar problem, and used some of that plumbers tape stuff over the threads of the fittings and it fixed the problem. give that a shot - it might be worth the 2 bux for that tape. :)
  3. jp0863
    Aug 15, 2004
    566
    clovis, ca
    hmmm, already have the tape, might as well give it a shot, thanks
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    It's common to have leaking oil lines. Evidently the aluminum tubing and crimping used is a little weak. Most reccommendations I've read are to go with something else than stock lines.
  5. jp0863
    Aug 15, 2004
    566
    clovis, ca
    well i finally had time to look at it. it appears the line was rubbing on the body seam in the firewall and make a small pin hole which caused the leak... new freakin hose too. i was more careful with this one and made sure there was plenty of clearence
  6. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Mine look ready to pop...
    The oil cooler lines on my 82 K20's 6.2 are rusted where they come out of the block,and where they turn to steel behind the radiator...When they start leaking,I'm hoping I can have new hoses made from regular hydralic hose like a backhoe would have..that hose has steel braid under the outer rubber casing,and is extremely durable(4000 psi rating!)..if not,I'll try to find barb fittings to allow bulk hose to be used with clamps..
    I'm not using GM OEM hoses (if I could even get them still!)..they are cheap vinyl tubing with aluminum crimp collars,and I see lots of them come "uncrimped" and pop off on 350's and in S10's,and blow the motor up in short order when all the oil gushes out!..and they aren't cheap either!(100+ bucks-!)-I've seen new ones pop in two months on one customers S10,now he's got low oil pressure,and it knocks when first started.....:doah: :crazy:
  7. jp0863
    Aug 15, 2004
    566
    clovis, ca
    got mine from napa, they seem better then oem and cost $50.
