oil on drums!?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dleroy43, Apr 20, 2004.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I noticed something leaking out my driver side drum yesterday so I pulled it open and noticed that it was covered in gearoil. I found where the inner seal got ripped somehow. I bought new shoes and seals for both sides. now is it possible to reuse the drum if cleaned good and how would I clean it?? /forums/images/graemlins/burb.gif
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yes, reuse it, just clean everything real good with brake clean.
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Also check the axle shaft to make sure it doesn't have any burs on it that could ruin the axle seal.
  4. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    You'll end-up having to replace the shoes. I bought a new work-van a few years ago that blew a rear axle seal. It was under GM warranty & the dealer told me it didn't cover the shoes when I told him I wanted the soaked ones replaced. The gear oil soaked into the shoes & won't clean off with the brake cleaner. In the process of using your brakes, they'll heat-up & "boil" the gear oil back out of the linings. I took my van back 3 times (after b!tching everytime) before I told them to replace the shoes or I'd call Chevrolet. Shoes replaced.....problem solved /forums/images/graemlins/waytogo.gif
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah, i forgot all about the brake shoe thing, cool of ya to throw that little detail in. Just totally spaced that, sorry.
  6. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    reuse the drum clean with brake clean toss shoes into box and take back for core $$
  7. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    thanks for the help gonna get some brake cleaner and put on the new shoes and seals this weekend. I should just go to disk but my truck fights me with everything. /forums/images/graemlins/burb.gif
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Same thing happened to me, I cleaned the drums really well and replaced the shoes. No problems since /forums/images/graemlins/grin.gif
  9. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    If you keep having a problem with the seal, then it might need a sleeve kit. Over time, some rear spindles get a groove cut into them, and a stock rear hub seal will not seal anymore. Then you need to get a seal sleeve kit, which comes with a steel sleeve that goes over the spindle, and an over size seal.
