oil on the spark plugs ???
Discussion in 'The Garage' started by ilikeitloud, May 3, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    well my truck has been runnin like ass for the couple days shes burnin more oil then usual and so i decided to pull the plugs replace the cap,rotor,wire etc.. well i started pullin out spark plugs and found that a few of them had oil covering them what could be causing this??
  2. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    If its not smoking all the time (white smoke from the exhust), than its probably warn valve guides. If it seems to smoke, then you probably have some bad piston rings.
  3. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Like camok10 said it could be valve guides or seals or piston rings.
  4. dyeager535
    26,982
    191
    Smoking at startup, valve guides. Smoking when you get up in higher RPM's, rings.
    Obviously not always 100% correct, but a good guide.
    If you are burning oil, don't waste money replacing plugs, scrape the crud off the electrode, and re-install them.
    My worn 350 had one cylinder that liked to burn a bit of oil, the plug was always "fouled" (but never ran bad) so every oil change, I'd just pull the plugs (to make sure other cylinders didn't have problems) and clean any that were dirty.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]Exact same situation on my new 406...#8 cylinder will build crud up on the plug for some reason...just clean it every once and a while. /forums/images/graemlins/waytogo.gif
