Oil Oressure going up and down
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigd652, Jan 31, 2004.
  1. bigd652
    bigd652 Registered Member
    Jan 22, 2004
    26
    Michigan
    Just noticed yesterday that my oil pressure gauge will drop ro 0 then back up to 30 where it always sits. I can watch the gauge flutter around. Thinking if it were my oil pump it would just drop down to 0 and sit there. Could it just be my oil pressue switch is pooping out on me?
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Gauge is probably developed a bad connection to the printed circuit board on rear of cluster. /forums/images/graemlins/thinking.gif
  3. bigd652
    Jan 22, 2004
    26
    Michigan
    So nothing to big to worry about at this time.....
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It will do that if it's low really low on oil when you take off. Otherwise probably the guage or sending unit.
  5. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    Just as long as the lifters don't start talking. That would be a sign of a pressure drop especially at an idle. click,click,click,click,click,click. /forums/images/graemlins/waytogo.gif
  6. dyeager535
    26,975
    Does it "flutter" when you let off the gas, or just randomly?
    Mine "fluttered" when I let off the gas, only explanation I could come up with was a sloppy timing chain that was "jerking" the oil pump. As long as engine was at a steady speed (load or not) the gauge stayed put at a constant reading.
  7. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Low on oil??
    Check the dipstick (the one under the hood /forums/images/graemlins/grin.gif)
  8. bigd652
    Jan 22, 2004
    26
    Michigan
    OK so maybe it was alittle low on oil.... lol /forums/images/graemlins/wink.gif all is well again. Put in 20/50 this time. Burning it faster then i thought... Thanks for all the info. Did hear some chatter just for a brief time then i shut it off and put in some oil and all is quiet again. Think she is ok?
  9. Goober
    Apr 26, 2002
    2,222
    It's probably gonna be fine but it sure didn't help it any.
    20w50 is some pretty thick and gooey oil. Especially in your climate. How many miles on your engine?
    If your engine is worn a bit then thicker oil may help you nurse it along for awhile longer. I ran 90 weight gear oil in a 1971 Impalla with a small block back when I was in High School (early 80's) and it quieted it down really nice! The guy who bought it from me said it sounded great /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif. (I know, I know ..... but I was young and dumb)
    10w30 is USUALLY a better choice for most engines. If you have a leak, fix it. If you put thicker oil in it to slow the leak it will also slow the normal flow of oil to some of the more trivial parts of your engine ..... like your bearings. /forums/images/graemlins/shocked.gif
    I see you are new here. WELCOME /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
    I think you'll like it here, most of the rest of us do!
