Oil Pan and rear main seal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JayHornyak, Feb 10, 2003.
  1. JayHornyak
    JayHornyak Registered Member
    Feb 15, 2001
    18
    Clinton Connecticut
    Hey has anyone done the oil pan gasket and rear main seal on an 89 with a 350? I was looking at the Haynes manuel and the have me remoing the engine mounts ant liftine the motor up a little and etc. But I just can't see why. and I would like to know before I start if those a generic instructions for unlifted an 2 wheel drives. /forums/images/graemlins/k5.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    My brother pulled the pan on his truck and he didnt have to lift the engine. I think he may have had to work it around a little to get it back in though.
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    We didn't have to lift the engine but did have to back off everything behind it...Thats a given....a few of the oil pan bolts are a bit tricky to get to if you have oil cooler lines and auto tranny lines...once they are out the way it's all gravy. Quite a time consuming job but all in all not too bad.
  4. JayHornyak
    Feb 15, 2001
    18
    Clinton Connecticut
    What do you meen back off everything behind it?
  5. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    he means unbolt the tranny,and flexplate i believe. then move it back so that you can get inside it.
  6. JayHornyak
    Feb 15, 2001
    18
    Clinton Connecticut
    I only have to move that stuff if I am doing the rear main seal correct?
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm planning on replacing both the rear and front main seals on my 76 K5 (400cid small block) I plan on replacinng the stock oil pan with a deep sump pan, and replacing the stock oil pump with a hi volume oil pump.
  8. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Replacing the pan gasket is a piece of cake. Replacing that one piece rear main is what makes it a chore.
  9. BowtieBlazer
    Jul 15, 2001
    2,462
    Yeah, you got it! The tranny and what not has to come back to get to the rear main....replacing just the oil pan gasket should be a straight shot. just a little tight gettign it in and out with the flywheel/flexplate so close.
  10. JayHornyak
    Feb 15, 2001
    18
    Clinton Connecticut
    Cool I hope that is what is leaking All I can afford now is easy. Between a house 98% done a 20 month old and one comung is april who has time or money.
