Oil Pan Gasket
Discussion in '1982-Present GM Diesel' started by cegusman, Jan 29, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does anyone know of a one piece gasket for the 6.2 oil pan?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I've quit using gaskets on the valve covers and oil pans altogether. I just use a good quality RTV silicone, and follow the directions closely. This means laying down a good, solid bead, and allowing it to dry a bit before installing. I do, however, use the front and rear rubber seals on the oil pan, along with a dose of silicone. This has stopped most of the oil leaking problems.
    Casey
