*Oil pan question*
Discussion in 'The Garage' started by 1985K20, May 21, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    While changing the oil on my baby today, discovered a nice oil leak on side of pan...the pan needs to be replaced and i was just wandering if i have plenty room to replace without having to lift engine?? Looks like im good but just want to make sure.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yup, did one in a 77 K10 a few years ago. IIRC we had to jack the truck up by the frame, and let the front suspension to droop a bit to get it out.
  3. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Thats exactly what I didn't want to hear :frown1:
    But thanks now I know :o
  4. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Might come out..
    It might come out fairly easy,some years and models you had to take out the thru bolts in the engine moints and jack up the motor by using a block of wood under the oilpan,and then putting the bolts back thru and rest them on TOP of the mounts(might need small peices of 2x4's there for more clearance)--DONT FORGET TO TAKE OFF THE DISTRIBUTOR CAP!!--or you'll need a new one! :doah: --keep an eye on all the hoses,cooler lines,fan blade to radiator,etc that might get "stretched" too!..its a lot easier on a 4x4 than a car or 2wd,to get the pan off..most times you can get it off on a 4x4 without jacking up the motor,but not in all cases... :crazy:
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i think you are misunderstanding this... i would be happy to just have to jack the frame of the TRUCK up and do noting near removing the engine in order to do the pan.... i have don it before. its easy, but can get messy. let everything drip for a while if you are in a garage. this is the closest you are going to get to a COMPLETE oil change till ya do it again or pull the motor. anyway its not that bad, just some thick blocks of wood preferably large jack stands under the frame and then pull the pan. if you dont have jack stands that go high enough then remove the wheels and tires and support the frame by the jack stands letting the suspension droop more.
    Grant
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    just jack it up by the frame, and let the front suspension hang down, not touching the ground so you get full droop out of it. not a huge deal at all. if you're lifted at all, you might not even have to jack it up.
  7. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i changed the oil pan on my 86 k10 with 4 inches of lift with no problems at all, didnt jack it up or anything,
    i also helped my friend put an oil pan on his 91 k5 with no lift, we just had to take the bars off that run from the engine to the tranny
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive changed the pan gasket of both my trucks when they were stock. my k20 even had BAD saggin front springs, i did NOT have to jack the truck up, or the motor. its a little tricky to get the pan front edge over the engine crossmember. but was able to do it with out a jack. IIRC, my k20 also had shot motor mounts so the motor sat a little lower than normal.
    this is a great time to go with the 1 piece oil pan gasket, alot easier than trying to hold 4 peices up with silocone and not bumping them so they fall.
  9. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Well here's the truth bout the oil pan: came off right easy, no jacking, no prying :D ...jeese i love my K20!
    But the only thing is puttin them F***ING cork gaskets back in place without moving them :mad:
    So i pulled out my gray silicone to glue everything together.Now on sippin on a cold Budweiser coolin off :mad1:
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    should've taken TJ's advice and gone 1 piece seal. they're gray to put on. i'd almost bet with that silicone you get a nice leak and have to do it all over again.
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes those cork gaskets are a big PITA with the pan upside down. i will never pull the pan and not use a 1 peice gasket ever again after doing one. it was 300 times easier.
