Oil Pan Replacement
Discussion in 'The Garage' started by tremor, Mar 21, 2004.
  1. tremor
    tremor Registered Member
    Mar 20, 2004
    10
    CT
    How difficult is changing the oil pan on an '85 Blazer? The engine is a 305. crossmembers to remove? Is there anything else that should be done while I'm in there? Pickup tube maybe? Oil pump? Any brands or styles I should avoid or look for?
    Thanks in advance.
    Steve
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Very easy to change, nothing to remove other than the pan itself. Do yourself a favor though and buy the one piece oil pan gasket. It is about $25.00 but well worth every penny of frustration you will save yourself.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    2nd that pan gasket!!
    If you have an auto tranny and have the big aluminum converter cover with the rods going to it, You may have to take the rods off to give you some room. but Other than that, they will just about fall out!
  4. tremor
    Mar 20, 2004
    10
    CT
    There does look to be a lot of room under there. Sweet. I appreciate the one piece gasket tip too. So there is no need to change the oil pickup tube? -Steve
