Oil Pan & Timing Cover
Discussion in 'The Garage' started by skink4president, Aug 23, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    Quick question -
    On an early chevy SB where the timing cover and oil pan seal together is there a preferred order of installation? In other words, should I put my timing cover on first and then the oil pan? Vice versa? Any other tips for install to avoid leaks?
    Thanks again.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Fresh build , its timing cover first and use the proper oil pan rubber when putting the pan on .
    I have done a timing chain with engine in car , and doing the cover with pan installed sucks . It can be done , but I dropped the pan to the crossmember anyway .
