oil pressure 50 at start up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the excuse, Dec 19, 2003.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    i just put an autometer electric gauge in to tell my oil pressure on my carbed remanufactured 350. it reads 50 when i start it and im in so cal so its not exactly cold here. when i rev it up it maybe goes to 60 whats the deal? it this ok?
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    That seems perfectly fine. The oil is cold, therefore it is thicker, making for more pressure. The pressure should come down some after the engine has warmed up.
    ...As a side note, when I first start my Duramax on a cold morning, the pressure is about 100psi... /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
    John
  3. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Are you using a stock oil pump?
  4. the excuse
    Dec 9, 2003
    209
    san diego
    i dont know i got the truck 4 months ago and it didnt have working gauges until now.
  5. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    before I rebuilt my 350, I would get about 30psi at idle and about 45-50 at around 2500rpm. I put in a rebuilt 355 this summer and put in a brand new oil pump and pick up and now I get around 50-55 at idle and I'm sure its over 60 at anything over idle because the needle maxes out. And it's not a high volume, just a melling stock replacement pump from Autozone.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ive had a ton of chevies run peggeg over all the way 60 while warming up until are warm, but when are hot they barely run over zero at idle.
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Im in the High Desert up here. Winters in the 20's and summers in the 105+ degrees. My Blazer with lots of miles runs 60 at cold idle and about 35-40 when warm. It runs pegged (60) when driving no matter how hot or cold.
    My ElCamino with 15K on a new motor runs 50 at cold idle and 65+ driving when cold. When hot, it runs 45 and idles at 10-15.
    Im running 10-30 Mobil-1
    Rule of thumb is 10psi per 1000 RPM
    If I run Valvoline 10-40 Im lucky to get any reading on the ElCamino at idle when warm /forums/images/graemlins/crazy.gif
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    With my 454, I am running 10w-30 and when I first start it in the morning it idles at like 70psi...and tops out at like 85 when the revs get to like 2000. once everything is nice and HOTT, it holds 25psi at idle and 50 at 2000...
    Chris
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    50-55 at startup, 45 at cruising speed, and 15-20 at idle after its warm
  10. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    That is real good pressure.
  11. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    That sounds perfect to me. I have a newly re-built 355 (now) that runs about 55 psi on startup (will go to about 75 psi if you rev it up), but after I drive down the highway for a while, it goes to about 15 at idle. I would say yours is about perfect. /forums/images/graemlins/thumb.gif
    -Harrison
