oil pressure and battery volt gauges
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eastcoastk5, Aug 29, 2001.
  1. eastcoastk5
    eastcoastk5 Registered Member
    Aug 27, 2001
    24
    Beaufort SC
    my oil pressure and battery volt gauges dont work, I havent tried to fix them yet, I just wanted to know if this is a common problem to fix and if so where do I start?
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Did they ever work? Did they suddenly stop working after a wheeling trip or a mod? Check all the connections under the hood and behind the dash.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
  3. eastcoastk5
    Aug 27, 2001
    24
    Beaufort SC
    when i bought the truck they didnt work then, been working on other things until now
  4. dyeager535
    26,979
    Doubt the gauges are fused, but can't hurt. Check fuses. Other than that, more than likely in the cluster or cluster connection. Corrosion on the back of the gauges (the post/nut) is one common problem, as is the printed circuit board contacts peeling.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I have these guages from my truck. I don't need them, if you want to buy them, I'll sell them to you. They worked, (as in moved) when I took them out to make room for new mechanical aftermarket guages. PM me if you are interested.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
