oil pressure check
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by olbluebeast, Jun 15, 2001.
  1. olbluebeast
    olbluebeast Registered Member
    Mar 16, 2001
    16
    austin,tx
    my oil pressure guage says between 0 and 15 lbs of pressure and does not move much between firing it up and running rpms. the oil is full, the truck seems to run fine and does not clatter or overheat. what is the deal ? whAT SHOULD I CHECK? IS THE OIL PUMP PUMPING, IS THE GAUGE SHOT, OR DO I NEED TO REPLACE THE SENSOR FOR THE GAUGE, AND IF SO WHERE IS IT?
  2. maxq15
    maxq15 Registered Member
    May 16, 2001
    44
    Miami, Florida
    Well, I can probably get you started in the right direction. If you don't get the symptoms of truly low oil pressure than it would be relatively safe to assume that the indication is inaccurate. Most likely the sending unit. As for the specific location, that I'm not sure of. I had someone else replace mine when it was bad and wasn't there to see where it was. Sorry!
    Those who think money can't buy happiness don't know where to shop.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Replace the sender, it is located (normally) behind the distributor. It looks like a bell. Normally gold in color. If that doesn't solve the problem, it could be in the wiring. The best thing to do is to take a mechanical gauge and hook it up TEMPORARILY!! This gauge does not lie. You will probably find your sender or gauge is bad.
    My .02
    Hope it helps,
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    the sending unit is not the one behind the distributor. That is the low oil pressure shut off sender. The oil pressure guage sender is right on top of the oil filter. It does look like a bell and you can't miss it. Change that and it should (hopefully) change the reading. Or if you really want accuracy, go mechanical for the guage.
    Ben 87 Jimmy
    <A target="_blank" HREF=http://www.bens87toy.coloradok5.com>http://www.bens87toy.coloradok5.com</A>
