Oil pressure drops when hot
Discussion in '1982-Present GM Diesel' started by choll3, Apr 15, 2004.
  1. choll3
    choll3 Registered Member
    Apr 17, 2003
    21
    Las Vegas NV
    I have a 1986 CUCV Blazer. Runs almost perfect. I changed the oil pressure gauge from the dummy gauge to a number one. I can let the truck run all day and the pressure reads 25psi, when I run on the highway the pressure gauge reads 0psi the pressure does not go back up until the engine temp goes down. So on road trips the pressure stays at 0psi. I am a gauge watcher and it is driving me nuts. Oil pump or something else. I never get any knocking noise.
    Chuck
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Did you change the sender ? Sounds like you left the idiot light sender in ?
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Sending unit needs replaced.
    Casey
