oil pressure fluctuating?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by emoo99, Jan 20, 2003.
  1. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    when i start my truck in the morning my oil pressure on my 350 is at around 30.. then when i start driving it it drops a notch to i think it's like 15 or 20, then it will go back to 30 then a little above.. lately it's been staying below 30 for a while.. is it normal for the oil gauge to do this? if not what causes it?
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    could be three or more things, 1 bad gauge, 2 bad sender, 3 bad bearing. id start with the cheap ones first, sender and then gauge. check the connector on the sender for dirt or corrosion. and things along those lines
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I would say don't worry about it. Those numbers are fine. Even the fluctuation isn't too bad. My engine runs right around 45 psi, but gets weird sometimes and goes up to, and over, 60. But, I'm convinced it's the sending unit, not the actual oil pressure jerking around so much.
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    add a quart oil...thats what i do /forums/images/graemlins/smirk.gif
    Ryan
