Oil pressure flux
Discussion in 'The Garage' started by Todd 91, Aug 20, 2003.
  1. Todd 91
    Todd 91 Registered Member
    Aug 15, 2002
    30
    Middle Missouri
    Did some searching on here but didn't see this one. I have an 85 Chev, 305. The oil pressure, after the truck warms up, fluctuates at low speeds. Could this be an oil switch or sending unit or am I getting ready to grenade? If it is a switch or unit, where are they? I can't find a pic anywhere or a description. From what I've gathered here, there is a switch that has to do with fuel pressure and then a sending unit by the starter. Correct?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    where does it fluctuate between?
  3. Todd 91
    Aug 15, 2002
    30
    Middle Missouri
    I'll get the psi change tomorrow Confedneck. I didn't think it would matter the amount of flux. I guess it does if it's a normal flux. The only thing that worries me is that when it does move, it's a real fast change back and forth. Nothing smooth and only seems to go when the oil has warmed up real good.
  4. Confedneck
    Nov 1, 2002
    5,236
    sounds like a sender to me... /forums/images/graemlins/thinking.gif
  5. dyeager535
    26,975
    Check and see if it corresponds with how you are driving it...such as fluctuating when you let off the gas.
