oil pressure gague problems????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unick, Mar 24, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I have an 87 K5 and as soon as I turn the key the Oil gague jumps all the way to the right. What could be wrong with it and where SHOULD it be sitting?
    LMK
    Nick
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Sounds like a short to me. Check the wire is still attached the switch, then check the wire hasen't chaffed somewhere.Should be at zero 'till you crank up some pressure.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If it all check good, then the gauge is bad. Well actually the little ceramic resistor behind the gauge is what goes bad on gauge itself. /forums/images/graemlins/k5.gif
