Oil pressure gauge at 0. Sending unit or pump? Help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jan 20, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Occasionally the gauge will jump up a little, but for the past week it has been just hanging out at 0. I plan on going and buying a sending unit to see if that's the problem. Is there a way that I can check the pump and the sending unit to see what might be the problem? I don't really want to burn up my new Blazer's good engine.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Just to be on the safe side I would change my oil filter to make sure its not clogged. As you say its a new engine...maybe it deposited somthing in there for you to find!!!
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  3. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Fist check the wire into it its probably loose ,mine pegs out once in a while but most of the time hangs between 30 and 40 psi
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  4. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    It's probably the sender. My 88 had the same thing happen, but , i also found out there is another oil pressure sensor on the block , if your O/P drops it cuts off the fuel so you dont cook your motor.
    Bill Innes
    88' Jimmy
  5. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Let me get this straight, if the oil pump stops, it cuts off the fuel? That's cool. I need to go check the sending unit. Thanks
  6. Grim-Reaper
    7,385
    Atlanta
    Probably a sender or wire problem. Personaly I would lay my hands on a cheap mechanical gage and check the pressure just to be sure. GM V8's can run for a LONG time with low oil pressure. I ran one for a year that only had 3psi at Idle 15PSI max on the gas. Never made any noise ran fine till the day I replaced it with a crate.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
