Oil Pressure Gauge problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Dec 1, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When I turn my key into the on position (without starting the truck) the oil pressure gauge shoots to 60+ even though it has no oil pressure. When the truck is running it still is at 60+, so anytime the key is on it reads 60+. Does anyone know what is wrong or what my problem might be? Any help is appreciated. Thanks
    Harley
  2. unsane
    unsane Guest
    Sounds like maybe a bad ground? Anyone else?
  3. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    882
    114
    chico,calif
    Take the wire off the sending unit and turn on the key. If the gauge goes to 60+ then the wire from the gauge to the sending unit is shorted to ground. If it doesn't then i would change the sending unit.
  4. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    It has too much oil in it. Drain some out. Just Kidding!!! /forums/images/graemlins/grin.gif I agree with the bad ground.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Where exactly is the sending unit for the oil presure gauge? I have heard that there are 2 on some trucks. Which one (if there is 2) should I check. Motor is GM crate 350. I have heard it is on the drivers side head somewhere. Thanks
    Harley
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Harley,
    The oil press. sender on mine is on the very back part of the block on the drivers side just above the oil fliter....that is the only one I know of on my engine...THe BBC I am building has the oil sender on the front drivers side of the block...but that engine is f'd up; it has 3 temp senders...I would check for the ground issue...I had that problem earlier this fall...
    Chris
  7. dyeager535
    26,978
    The sender is typically next to the distributor, drivers side, a big "bell" shaped piece. One wire to the top of it.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    in what year ? '77-up electric, 76-down hydraulic tube operated
  9. K5Kell
    K5Kell Guest
    I have a similar problem in my '87 blazer except that even with the key off the needle is as far to the right as it will go. Is this a possible ground or is the gauge bad? I allready replaced the sending unit with no result.
    -Kell-
  10. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    Is the sender you're talking about go into the block right below the header? Also, what is an ideal oil pressure for a 305?
