Oil Pressure Gauge
Discussion in 'The Garage' started by Nike, Oct 4, 2004.
  1. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    Trying to get my O/P gauge working. I have mixed some different years when assembling the dash and wiring, and I think I have an 83 speedometer and gauge assembly/printed circut etc. and maybe a later underhood wiring harness because it has a connection for a second oil pressure sender. Anyway when I turn the on the key electric gauge pegs to the highest reading. Anyone have this problem or a hot tip. Thanks Nike
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    That means that your oil pressure wire is grounded out somewhere.
    Thinking about coming out to the Fall Crawl ?
    Blake
  3. dyeager535
    26,979
    Are you using the large, bell shaped oil pressure sender?
  4. Nike
    93
    Yes I am using the large bell shaped sender, I tried the later model smaller one and got the same result. Also yes I am going to make the fall crawl on Saturday only. I would like to make the stock gauge work if possible, but if it doesn't happen I will hook some plastic tubing up with a plain pressure gauge. Any ideas are greatly appreciated. Thanks, Nike
  5. dyeager535
    26,979
    What happens when you disconnect the wire from the sender?
    It does sound as if the wire to the gauge is grounding out somewhere. No connection to the sender (ground) the gauge should sit at 0. If you ground the sender wire to the block, it should peg out at max.
