Oil Pressure Gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Feb 23, 2003.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    Ever since i got my k5 last year, the oil pressure gauge hasn't worked properly. The gauge reads anywhere from 15 to 40 psi, but it never moves after being turned on. wherever the gauge is when the engine starts is where it stays(usually around 35 psi). I want to replace the sending unit, but I don't know where it is on my engine. Can someone please tell me where to find the sending unit on an 85 305.
  2. dyeager535
    26,979
    Believe they are all on the drivers side right near the distributor, kind of bell shaped. At least mine is on the '74 motor I have.
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    On my 83 it's above the oil filter.
  4. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    if its not identical to yours, its very close, it'll be in the back near the distributor, not the easiest thing to get to, but not horrid. i couldnt get mine to work at all, so i trashed the electronic one and went for the old style mechanical guage...
    all i had to do was run the oil line through the firewall and mount the guage....of course i'm lazy so to mount it i just shoved it in the ashtray at an angle....
