Oil pressure guage?????
Discussion in 'The Garage' started by TB2Blazer, Dec 29, 2004.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    I just bought a cluster of guages for my K5 and was wondering where does the oil pressure hose plug into the engine from the guage? Is there a certain spot where I can just screw the fitting into the engine? If so where the heck is it? Thanks.
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I believe mine is screwed in behind the intake manifold towards the drivers side on top. I'v got a 400 but I think the 350s are the same.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The oil pressure fitting is in the same spot on my 388 (350 block).:waytogo:
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    yup , that spot exactly . Don't use the plastic line , go get the same size hardline from hardware store , or pirate one of a 75 or older blazer/pu :xmas:
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    You can put it in the block behind the distributor. There is probably a round bulb looking thing with a wire on it there now. It is the sending unit for your current gauge. You can unscrew it and put the fitting where it was. I usually use a small length of pipe (1" to 1 1/2") to make it easier to get my wrench on the fittings.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    you can also go in the block on the side, directly above the oil filter boss usually.. a 1/8 NPT hole...
