Oil Pressure Guage
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bdkmiller, Aug 2, 2002.
  1. bdkmiller
    bdkmiller Registered Member
    Jul 31, 2002
    42
    NH
    Hi,
    Just got my first K5, a '72 in very nice shape. However it needs a little bit of work. The oil pressure guage is not hooked up & I am not clear how this is done. There is a sending unit in the engine but it appears to be electrical & as far as I can tell the guage is mechanical. I have the tube from the guage but I can't see where to connect it.
    Can anyone point me in the correct direction?
    Thanks,
    Brian in NH
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The tube connects to the normal oil pressure sender port that is behind the intake a little to the drivers side from the distributor. If someone has installed a later model engine, they may not have swapped the fitting that you need to hook up the tube into the new engine when it was installed.
  3. bdkmiller
    Jul 31, 2002
    42
    NH
    Does this mean it does not connect to the sending unit? It is possible that this is not the original engine.
    Thanks,
    Brian
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    the stock gauge didn't use a sender as it's a mech. gauge.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    engine temp has a sending unit on the passenger side head.like it was said here.the is a fitting on the back of the engine next to the distributor that the tube coming from the oil pressure guage is supposed to hook into.shouldnt cost much for a new tube and fitting from an auto parts store,as long as the guage still works /forums/images/icons/laugh.gif
  6. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I replaced mine with a copper tubing kit. You can find one at most auto parts stores and they come with several different fittings that will work on most guages.
