oil pressure line.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 68MUDSTUD, Aug 24, 2006.
  1. 68MUDSTUD
    68MUDSTUD OCD with shiny things
    Sep 30, 2005
    9,448
    MT
    hey anyone know where i could find a new oil pressure gauge line for my 71 ballzer? i checked at chevy duty and LMC and couldnt find anything. i googled it and everything, any help is appreciated. Time is money!!!
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    Just grab some 1/8" copper line (most real parts stores will have it). You'll need an Edelmann-111200 fitting to attach to the gauge then use any 1/8" pipe-1/8" compression fitting to go into the back of the block unless you still have the original fitting in the engine then a 111200 will work there too.
    1/8 x 1/8 compression fitting Edelmann 168220 (everco 66a, weatherhead 66x2)
    1/8 double compression (stock gauge and engine fitting) edelmann 111200 (everco 11a, weatherhead 6100x2)
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    WOW your factory gauge still works :eek1:
    I ended up tossing all the old guages for AutoMeters. Plus my oil press guage leaked :doah:
    good luck
    Burt
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Mine still works too-no leaks.:D Still have the OE steel line on it, also.
  5. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    I'm impressed, wish mine leaked just so I could go out check out all those parts! Nice work
    Burt, if you kept it on all the wheels maybe your gauges would still work.J/K
  6. Burt4x4
    6,854
    :p: hehehee
