Oil Pressure Problem!
Discussion in 'The Garage' started by Mr.Jimmy, Dec 28, 2006.
  1. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    buddy o mine's got a 02 gmc z-71, his gauge will peg out so he'll shuter down. starts it back up and itll run low psi then itll vary a while. whats going with it. opinions appreciated.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I don't know much about the newer trucks, but I would suggest he replace the pressure sender and see if that clears it up. Start with the small easy things, brother!!! :thumb:
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Take out the oil pressure sender and hook up a stand alone oil pressure gauge and see what it says.
  4. Mr.Jimmy
    Nov 20, 2006
    66
    Albuquerque, NM
    thanks for your thoughts guys.
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    newer trucks have dash cluster gauge problems. best check with dealer to see if its under recall or tech bulleten for problems.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    What he says. And if it still acts screwy......nuke it from space, it's the only way to be sure.:D
  7. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Some of the newer oil pressure senders are tied with the low oil pressure fuel shutoff. Pull it and it won't run.
  8. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i would check the sending unit, maybe its about to go tango uniform
