oil pressure sender Q
Discussion in 'The Garage' started by willyrocket, Aug 28, 2006.
  1. willyrocket
    willyrocket Registered Member
    Mar 8, 2005
    24
    Cape Cod, MA.
    Adding a electric oil p sender to the back of the block. Can I do away with the stock sender? It appears in the wiring diagram, that the oem sender goes to the computer. If I add the aftermarket sneder, do I need to splice the original wire into it so the computer still sees oil pressure? Bytheway, its a 90 with a 350 TBI.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Why not use a T , so both components have a sender . There are two oil pressure ports already you could tee from if you count the one above the filter .
  3. dyeager535
    26,980
    Thats the fuel pump relay oil pressure *switch* not sender. Keep it.
  4. willyrocket
    Mar 8, 2005
    24
    Cape Cod, MA.
    So now I am thinking that I will put the aftermarket sender in the port above the filter. Sound good?
    So where does the dash get itsinfo from, the oil p switch still?
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I thought it was a sender/switch?
  6. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Its a backup for the fuel pump. Once pressure builds up, it turns on the fuel pump. If the relay goes bad, you can still run the motor. You can do without this switch, as most carb to TBI conversions do, but its worth keeping :) The dash guauge gts its singnal from a sender on the other port.
