oil pressure sending unit
Discussion in 'The Garage' started by supernaut, Nov 30, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    where is my oil pressure sending unit?!
    On my '75 blazer with a 350 I am assuming it's the cylindrical thing threaded into the left hand side of the block between the spark plugs (numbers 1 & 3 i believe). I scoured my Haynes manual but found no info. And in that vein where is my coolant temperature sensor? All I see in my thermostat cover is a plug threaded in.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    the thing between cylinders 1 and 3 is your water temperature sending unit. The oil pressure sending unit is to the right of your distributor, and a REAL pain to get off :wink1:
    James
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    x2, ugh
