Oil pressure sending unit
Discussion in 'The Garage' started by dogdaysunrise, Feb 26, 2006.
  1. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    I was reading through all the posts on here, and they all say that the oil pressure sending unit is just to the right of the dizzy. My question is this, I was flipping through my haynes book and it says it is located down by the oil filter. Is the location diffrent on my block? It is a 92 tbi in an obs truck. Or is that a sender for something else?
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    You can use either port for oil pressure. Mine is not stock, but the one by the oil filter goes to a manuel aftermarket gauge. And the one by the dist. goes to the computer/fuelpump relay that shuts down the fuelpump when the engine loses oil pressure.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    On my 84, the oil pressure sensor down by the filter is hooked into the cutoff system, and the sender by the distributor is for the factory gauge.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    My 87 305 TBI has the upper sender for the fuel pump cut off, and the one just above the oil filter goes to the gauge in the dash
  5. dyeager535
    26,976
    As you can gather by the posts, location was different based on application.
    I'd be surprised if your '92 doesn't use the integrated sender/switch like I've got, 3 wires. Trucks started using it at some point, the '91 454 V3500 I took apart had it. May have started use in 1989 or so, you'd have to verify against the wiring manuals. Does your Haynes show the wiring? (typically the Haynes wiring manuals are too generic, but in this case it may be ok)
  6. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    well I am going to add a mechanical oil pressure gauge probably either later on today, or sometime tomorrow. I will have to look in the book and check for wiring. The exsisting gauge is electrical. I actually havent gotten the energy yet to go lay in the snow under the truck (neon with half the motor ripped apart in the garage, dont ask) and take a look. Maybe later today.
  7. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    okay I just took look. I have the 3 wire unit like you had said Dorian. There is a threaded hole about 3 inches above the oil filter with nothing in it. Would this be where to hook up the oil pressure gauge? I am going to go take a picture of it in a second.
    ----- EDIT -----
    Here are the pictures, sorry kinda bad angle.
  8. dyeager535
    26,976
    Standard block, yes everyone knows what/where that is.
    You can use this, as stated, GM did in some applications. You say nothing in it, but I assume there is at least a plug in it!
    In my experience that is not the same 1/8" thread that the upper one is, it's larger. Also, because of the casting, you can't thread a sender directly into it, so you'd have to use an extension. All sorts of problems with that and headers, at least in my case. If it's just a barb fitting you are installing, if it will fit, it will work. :)
  9. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    It uses a compression sleeve fitting to a nylon hose and comes with all sorts of adapters for diffrent sizes. If I just thread this into the block will it read accuratly? or will I need to get something to actually go deeper into the casting?
  10. dyeager535
    26,976
    Those are hard to tell what I'm looking at..drivers side of engine from the rear, right?
    The hole with the plug in it is the one you want, I *think*, if it was from the angle I always see mine from, it is directly above the oil filter mounting pad.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Same as my 83 . If I unplug the sender , the choke light stays on .
  12. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    yea your right on the picture location. That would be what you are looking at. Good to know. Im gonna try and thread it straight to the block and see how it does.
  13. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    does the sending unit in question by the oil filter by chance look kind of like a fuel filter with 1 connection coming off the end. im trying to figure out where the problem is with my oil pressure gauge, its pinned all the time. would running a high volume oil pump cause a problem?
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Do you know for a fact that you have the correct sender for your gauge?
  15. readymix
    May 30, 2004
    6,706
    26
    Mine does
  16. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    yes, it worked fine before it was stuck, then it just stuck to 100+ psi one day
    i bought replacement sending units and replaced the one behind the distributor and it didnt help at all, i couldnt figure out if there was a 2nd one that might be causing it. should i try replacing that one above the earl filter or should i be ripping apart my dashboard?
  17. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    was just messing with mine today, no signal = 3 oclock position... hope that helps
  18. dyeager535
    26,976
    If the gauge moves when you disconnect the sender, then ground it, it's likely it is only the sender that is the issue. If that doesn't do anything, you've more than likely got a wiring or gauge issue.
  19. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    the one by the filter is the switch for the computer and engine cut off, its a safety basically to keep you from starting it with low or no pressure
    if they are working right anyways
    the sender for the dash guage/light is just behind the distrib
    noobs
    looking in a haynes is the first mistake
    good luck
