Oil Pressure Sending Unit
Discussion in '1982-Present GM Diesel' started by AzzKicker, Sep 7, 2002.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Bought some aftermarket guages and I got water temp, voltage all hooked up. But I cant seem to find the oil pressure plug. The guage has a vinyle tubing that needs to go somewhere but i dont know where I could put it.
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Not sure but I think you bought a mechanical gage and I think you need a electric one.
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    The oil sender from the factory is on the back of the engine by the vacuum pump .The only place I can think of
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with Tybee. It sounds like you either have to buy yourself an electric gauge or take out your electric sender and install a mechanical one.
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The stock electrical sending unit for the oil pressure is shaped like a bell, has one wire pushed into it on the top, is mounted at the rear of the engine on the block, pointing up. Use a 9/16" wrench on the bottom of the sending unit to unscrew it. Then screw in the fitting that came with the guage.
    There is also a plug in the side of the engine above the oil cooler lines, but it's hard to get to.
    Casey
  6. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    so the one thats easiest to get to is behind Air filter. Is it pretty visible?
    Its on top of engine right?
  7. Can Can
    15,552
    136
    It's on the top of the block on the driver's side of the vacuum pump, which sits in the same place as the distributor on a gasser. Like Casey said, it's screwed in and looks like a little bell with one wire attached to it at the top.
