oil pressure should be?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefjerky, Apr 17, 2002.
  1. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    86 k5 with stock 350/700r4/np208. what should the oil presure read? my needle on the gauge keeps bobbling between 30 and 60. what causes this?
    thanks
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't depend on an electric guage to be accurate...
  3. dyeager535
    26,982
    191
    I believe you could measure resistance between the sending unit and the block, to see if its gauge or sender. Even then, I don't think there is an accurate way to tell if the sending unit is bad or if the oil pressure is actually varying, short of a mechanical gauge (even though they are still gauges requiring calibration).
    A "coincidence" I've noticed is that bad sending units rattle quite loudly when shaken if they have failed. Not sure if thats universal or not, but all the ones I've had that have rattled, did not work.
    I replaced the sending unit on my truck, the needle jumps very slightly at idle now (better than before) and I've swapped three gauges 'cause I had spares. It's not the gauges, and I doubt its the sender, I think the oil pump is getting sloppy. I would say typical is 30 or slightly less at idle, and 30-45 cruising. "Safe" idle is claimed to be as low as 5PSI hot, but obviously if you are down that low, you've got some problems.
    Mines started idling at 15PSI hot, and making some noise...hope the machine shop gets my balance job done so I can pull this motor out before a bearing decides it needs to move.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    My gauge is almost always pegged at 60...when it gets nice and hot, it drops below 60 a bit at idle...I think my factory gauge is the biggest problem...
    Chris
  5. dyeager535
    26,982
    191
    Well, you gotta troubleshoot to be sure. I'm constantly amazed that Chevy truck owners seem to be the only ones with stock gauge problems, yet almost all other GM vehicle owners have NO complaints, except visibilty with stock gauges.
    My dads K20 454 also pegged at 60 and stayed there all the time. When he got a stock 80PSI unit and the correct sending unit (yes there are two different sending units AND gauges) it was confirmed that PSI was actually that high, the 60PSI gauge and sender simply couldn't indicate that high pressure.
  6. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    Mine stays pegged right about the 40psi mark.. 350 with about 200k miles.
