oil pressure switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fright89, Mar 11, 2003.
  1. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    i am still working on a no power to fuel pump problem
    Can i bypass the oil pressure switch? tried taking the old one out but it is frozen in there. I sprayed rust desolver all over it and will try again in a little while.
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Make sure you have oil pressure. If it is a one wire switch, then it probably grounds out so to bypass it ground out the wire. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If the pickup coil in the distributor or distributor module goes out on these trucks, the fuel pump will not turn on. It prevents flooding the engine. That ended up being my problem. Don't forget to check the fuse for your ECM.
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I had the same problem as 89Sub did, only on a 90 GMC 1/2 ton pickup. Drove me CRAZY until I finally read the right book and figured out what it was. I replaced a coil and a fuel filter... and spent about 3hrs under the hood with a multimeter trying to find the damn problem....
