Oil Pressure WHACKED!! HELP!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadJap, Aug 10, 2003.
  1. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Well, fired the motor for the first time tonight... it started first turn of the key. BUT the oil pressure gauge is stuck way past 400 mark!! So my wife killed the engine right away. Even with the truck not running it's stuck at 400 as well as when I disconnect the battery!
    Any ideas on what's going on???
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    400 PSI? Gotta be a bad ground. Hook up a mechanical guage. At least you have pressure.
  3. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    When I got my '87 K5 the oil pressure guage was not working and I replaced it. Now it seems to constantly read around 40 to 60 and I suspect something may have gone awry during installation or that K5s in general have Oil Pressure Indicatior problems. Your debacle seems to substantiate my theory. At any rate, it could be that your indicator hose running from the engine to the Oil Pressure Guage is pinched or damaged-that will mess with it's accuracy.
  4. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Does the pressure gauge not go back to 0 when the engine is off or the battery is disconnected?
    I have to admit, I did drop the oil pressure sensor just before I installed it.. /forums/images/graemlins/blush.gif So it is possible it's toast, but I figured the gauge should at least go back to 0 even with a bad sensor.
    Are there any special directions for installing the sender? Telfon sealant or no?
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'd day bad gauge or sender.
  6. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Are there any known ways to test for a bad sender or gauge? I'd hate to have to replace stuff on a guess.
    (Both worked fine before new engine install)
  7. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    Not wanting to replace the guage on a hunch is definately understandable! I do not know if there is a way to test them, but I do seem to recall reading that teflon tape around the threads where the sender enters the engine is a capitol idea.
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You got yourself a bad gauge there. I bet dropping it toasted it. Go to autozone and buy a new guage. That will fix it. Believe me, you cannot get 400 psi out of your engine. And if it doesnt go back to zero then its a bad guage.
    -Harrison
  9. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Hi, I replaced the sender unit... Problem solved.
    I read that if the gauge is wrapped to high side of the gauge when the key is out of the ignition, and won't return when you put the key in and turn it... bad sender - makes sense since I did drop the poor thing.
