oil pressure. what do you got?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by curtis151, May 17, 2001.
  1. curtis151
    curtis151 Newbie
    May 17, 2001
    4
    i recently rebuilt my engine and my oil pressure isn't what i expected it to be.i'm just wondering what everybodys running cold and hot at idle with truck in drive...........
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    In the mornings when everything is cold it runs above 45. Than after its all nice and warm and its running on the open road it'll drop between 45 and 30. What is yours reading. Using the stock gauge or aftermarket. The stock ones arent the most trust worthy.
    <A target="_blank" HREF=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</A>
  3. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    Well not that is a fresh engine or anything close, but my oil pressure is a solid 30 all the time.
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have a high volume that runs about 65 pounds. After it warms up it drops to 45 at idle then shoots off the chart when I go
    Brent
  5. dyeager535
    26,975
    Old motor, unknown age, mileage, parts, 30 psi+ cold, just under that hot idle, with 20w-50
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  6. curtis151
    curtis151 Newbie
    May 17, 2001
    4
    I'm running both a stock gage and a after market gage on a T-pipe.The stock gage is off.Cold start up i have 60 psi but when it warms up after about 20min it drops to 20 psi.(this is at idle and in drive)I know what the problem is I just don't to belive it...................Thanks for the imput
  7. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Mine runs about 50 on cold startup at idle and about 30-35 at idle when up to temperature (190). I run a stock new GM Z28 pump and 7 qt. pan with 10W40 oil.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 Vortec stroker. Build it Bulletproof and take it fishing!
  8. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    My 350 used to run about 35 to 45 all the time. I switched to mobil 1 synthetic, and now it runs about 40 cold and sometimes drops clear to 15 when it is hot. I am not concerned because i know the pump is not bad, and the engine only has about 40k on it. I guess it is just the oil. Synthetic runs out of the bottle like water, so i don't see that it would be any different in the engine.
    eric
    Hell, it don't really matter....it's just for my race car.
  9. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I had the same problem.... in my case it wasn't good. Turned out that my crank was bad, the journals were out of round. When cold I had 60 + psi pressure, once warmed up it started off being about 20 ish or so and as a week or two went by it decreased to zero at idle. All kinds of not nice noises begn to follow. Just keep an eye on it, I ended up having to do the low end of the motor again, kinda sux when it only had 500 miles on it.
    You call that dirty!?
  10. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Solid 30 all the time when warm. (though the needle vibrates. duh!)
    "K5 Grand GT Blazer Silverado in the Netherlands."
  11. Greek
    Greek Registered Member
    Jan 29, 2001
    9
    Long Island, New York
    In the cold winter mornings of New York I rread around 45. As the oil warm it goes to 30.
  12. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Running the manual required 5w30 w/ 150,000 mines runs at running temp, 45 while on the gas adn at idle 30.
    Speacking of which, I live in a hot humid climate area and much traffic and my manual says 5w30, would it hurt or be better to run 10w40 in the summer?
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  13. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    my 87's origional motor (going on 114K) runs pretty low pressure. usually starts around 30PSI, then drops to just above 15.. and this is with 20W50 oil! I think that this is the beginning of a problem, or the gauge is just screwed up.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
  14. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I heard that 10w40 was a screwy oil weight. I run 10w30 Valveoline all the time here in Texas.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  15. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I run 10w30 and have about 40psi cold and 30 when it is warm.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  16. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Ah, a fellow valveoline user. Can't stand that Penzoil junk.
  17. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Mine has a new gm 350 crate in it w/ 20,000 miles and i have the stock gauge. It run s at like 50 when i start up and at 60 when im on the gas or just drivin.
  18. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    semi-worn motor runs anywhere from 40 -60 psi depending on temp and rpm. I like Valvoline oil (well duh they used to be one of my sponsers so I gotta like em... but they are the best IMO) I usually run 10w30 summer and 5w30 in the winter... although if I had a fresh engine that I cared for I'd run my 10W40 synthetic. Just my opinion here... but if you run 10w40 or thicker oil I'd definetly let the truck idle a few minutes before you take off because they usually are pretty thick cold on startup and don't lubricated real well cold... that or run that d@mn oil suppliment... arrggghh can't remeber the name right this second... Too much alcohol last night [​IMG]. I'll have to post it later...
    1987 Chevy K5 Blazer- 350 TBI
  19. angelglo
    angelglo 1/2 ton status
    Aug 4, 2000
    105
    S.F. bay area
    rule of thumb. just as long as you keep it above 10 psi for every 1000 rpm, you are fine. if you go below that, start saving money for a rebuild.
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    Another user here, too! Also hate the Pennzoil crap, too!
    My 454 runs right at 60 lbs. cold. When warm, it will jump around the 50 to 55 lbs. range.
    When In Doubt, Whip It Out!
