Oil Pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAPTAINK5-CT, Apr 25, 2001.
  1. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    Ok, when I start up my pressure runs about 60 on the stock guage. After warm up, while cruising it stays around 30+. After warm up, while parked and idling it drops to the notch before 30. It used to always stay around 30. Any thoughts? Please don't tell me it's the bearings.
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Have you changed the oil recently? Possibly the oil pickup tube could be clogged/obstructed. How many miles are on the engine?
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Is it an electrical gauge? If so, maybe the sending unit is cracking out on you. Get a mechanical one.
    '73 K5
    Chevy good...Ford bad
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd pop for the 12 bucks and replace the sender - sounds like it'll solve your problem.
  5. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    What grade of oil are you running? If the engine has higher miles, the clearances may have opened up enough that oil may be escaping out of various places before reaching the pressure sensor. Try running higher weight oil. Also, the pump itself may be wearing, so that it can't pump as well as before.
    Email: xiaozhu@my-deja.com
    ICQ: 84108805
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    How many miles? What type of motor?
    Assuming it's a chevy small block that has some miles:
    A small block is not in danger even with 8 psi. The pressure you're running is fine. The motor is not new anymore (which I am assuming) and it wears and opens up a bit. When the bearings start to go, it'll drop real low. You can replace the sending unit if it'll make you feel better. If that makes it better, then great! If not, then you're only out 12 bucks. I think it's your motor showing some miles on it is all.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  7. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    I have the EXACT same readings on my '87 stock 350. I have about 81,000 original miles. I have no problems and was told by my uncle (1st owner) that it always ran that way. I wouldn't worry about it.
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Nothing to worry about. You would not have any problems with 5 psi at idle.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  9. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    30 psi? Haven't seen that in years!
    88 / 350 / 185,000 miles, just started to puff at start up. Still going strong ...
    Don't worry about it!
  10. CAPTAINK5-CT
    Sep 10, 2000
    124
    CT, USA
    86, 305 with 114,000 on the clock. Thanks for the tips, now I have stuff to work with.
  11. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    My 86,305 with 135,000 still runs 40 at idle...I just change the oil every 3000 abd it runs great...
  12. maddog
    maddog Registered Member
    Mar 15, 2001
    12
    MISSOURI
    The small block requires about 10psi for every thousand rpm's
    10 psi=1000 rpms
    60psi=6000 rpms
    Read this in Hotrodding the small block chevy its an old book but good
    Hind sight is always 20:20
